Any Major Front Seat Floor Pan Differences - '67-69 Dart vs. '70-'74 Duster
ocdart
Inland Mopars Car Club
North OC, SoCal
I want to have some custom seat bracket/mounts built for my '69 Dart that will be finally coming home from body shop/paint prison in a week or two. Now that the body and paint will be new and perfect, I'm not thrilled about possibly having to take it out to a shop for measurements and fabrication of the new bracket/mounts for the bucket seats.
It was originally a bench seat car and I'm switching over to aftermarket buckets.
One of the fabricators I've talked to has a Duster project at home and he's had Dusters in his shop. Are there significant differences in the front seat area between the '67-'69 Dart floor and the '70-'74 Duster floor? I'm wondering if he could use his at-home Duster for dimensions to build the bracket/mounts for my Dart if I supply him with my aftermarket seats and sliders.
What say the experts?
Thanks.
I am sure others will chime in, but This may be of some help, here are some AMD pan repops. I am guessing with some searching of resto threads on here, could yield some factory floorpan pics as well. Glad to hear paint is done and close to finally getting your car home, and can totally understand you not wanting to put it back out there risking damaged, good luck. Oh, and you got to post some pics for us when you get her home.
1967-1974 Dodge Dart Parts | MM1383 | 1967-74 Dodge Dart / 1971-74 Plymouth Scamp Full Floor Pan | Classic Industries
1967-1974 Dodge Dart Parts | MM1384 | 1967-74 Mopar A-Body Full Floor Pan | Classic Industries
Thanks.
He can use the Duster for the seat bracket fabrication. The floor pan is identical to that of the Darts forward of the rear seat foot wells. The only difference in the floor pans ‘67-‘74 is the length, and the extra 3” the Darts have in the floor pan compared to the Duster is well behind the front seats.
‘75 had the catalytic converter bump added to the floor, which does change one of the floor brackets. So as long as he stays ‘70-74 it should be fine.
