Are high back buckets hard to do? Or can your average guy do them? Seat foam needs to be replaced.Should I turn it over to a shop or can this be done. One shop here the guy cuts foam to fit with a knife the other shop dye cuts them with CNC machine, or will the Classic Ind. Or Legendary foam work. The installation sheet says it can be complicated. What should I do?
