I have an 800sq. Ft. Building I would like to power off grid. Just need enough power for lights.
Anyone do this type work?
I LIVED OFF THE GRID IN Hawaii FOR 7 YRS, BUT BY NO WAY AN EXPERT. If you are not in there 24/7 you can get away with a 40 watt panel, 12v leds (there are tons of styles) and two batteries. Right now I have 3 15w chepo harbor freigt panes on my garage to maintain batteries and a 2000w inverter (for the occasional 110vac) I had around. I usually have one battery on the bench and a cord to whatever lawn mower, tractor or car that needs it. Works well. The harbor freight one surprised me how well it worked out around 170 when on sale and comes with 2 12v drop lights that are fairly good. The junction bay is also wired for usb 3, 6, 9 and 12 volt. I usually put my mp3 in it while in the shop. Just putting it out there. Wind I use in my hops field with a delco alternator with a modified rotor and it runs a 12v pump to pull water out of the pond. It also has a junk battery with a regulator. puts out 20 Amps in a 25mph wind. If you want to build one let me know I have a spare set of composite blades for one.Ray
Codes? What's that? We live in an unincorporated third world county....damn near anything goes....and before a certain someone starts on me, again, about this I realize that even we do have codes...enforcement of them is another gig though.If you plan to run power tools, the generator WILL be your best option compared to straight solar. The battery capacity and inverter will cost more than a generator, and will probably be more than a permanent installation assuming power is reasonable close by.
If the building is a temporary structure, or an "agricultural outbuilding" that may need to be occasionally relocated, you are best off either using a "construction temporary" service, or permanently mounting your meter and disconnect to a pole and mastheading to the structure. If the structure must move frequently you could set up an "RV service" and just plug the structure in as needed.
I'm really curious exactly what codes prevent this? What I describe above is common practice for job sites, trailers, construction offices and people who want to put a small shop into a garden shed on skids, or a "tiny house". If you're trying to skate around a CCR or HOA rule that specifically prohibits exactly what you are trying to do my best advice would be to appeal for a variance before you start. If you get into a fight with one of these entities, you will lose (potentially a lot).
In any event, my advice is to follow all applicable codes and best practices.
No problem Ray.Pm sent
Ray,
How did it work out?
OldManRay said:Any solar or wind experts?Rob (RustyRatRod) is usually pretty gassy. Does that help any?
Robs been kind of quiet lately. :sad8:
He's over on facebook quite often.
