71dusterdan
Hey everyone, in my years of aquiring parts I picked up a real affinity for Thermoquad carbs. I have 2 la blocks, and a set of magnum heads off of a 5.9. I also have a Performer intake. I havent mag'd the heads yet, so they may or may not be good. I would prefer to use what I have....I am not looking for big power 370-400 would be just fine. Is there an intake that will work with my carb and mag heads? Or is there an aftermarket magnum head that will use my old intake? I know the intake could be drilled, however I havent got the 1st idea how to do it, or if any of the area machine shops are qualified to do it! I figure a set of flat tops, a mopar .509 cam or even smaller variety of a Comp Cam or Hughes cam, good headers 3 angle valve job in the heads, and gasket match to the intake should get me right where I want to be. Thanks. Dan
