fuzzman
Hey all I'm in the process of installing a set of eddy 6077 heads with a air gap intake on a 408 stroker motor and when I went to install my alternator i discovered that the heads stick out to far on the bottom so there is no clearance for the alternator to swing down into place. Has anyone ran into this problem before? Do you have to roll the alternator up higher and go with a longer belt? Or is there a different alternator bracket that they recommend that you use? Any ideas?
Pat Faley
67 Notchback Barracuda
Peoria IL
Pat Faley
Peoria IL
