I think RAM changed their customer service strategy for the better using the online form that is offered.
That sucks. And blows. I can do more in a 5 minute call than I can in an email or some form.
I’ll pass on that.
1000000000% agree, I detest online help. Get me someone with some skin in the game, on the phone.That sucks. And blows. I can do more in a 5 minute call than I can in an email or some form.
I’ll pass on that.
It will lolLooking forward to sharing data once I get ours in the GTS. Does your bellhousing have an adjustment window?
Update.. placed an order for a Ram adjustable 10” clutch!
Waiting till it absolutely needs it. It’s coming with 550 base springs if I remember right.Looks like faceplating may be in the TKX's future
1200lb springs in the PP?
Grant
Clutch came in. Excited to get it in. Looks like I’ll have to trim the bolt stands a little bit for bell housing clearance
Aluminum with steel padsVery sexy!! Is the pressure ring on the pressure plate aluminum on that cover??
About two seasons worth of smoking a diaphragm clutch lolWhat’s the Ram part(s) number for this clutch setup? Cost?
No which I’m surprised but I’ll reach out to someoneDid Ram give you are starting tune up for that clutch?
I suppose Cale could tell you things about that clutch as well.
I have to figure out the lingo with talking to people on adjustments. The base is set to 550 at zero turns. So add 33lb per base spring? And 1g per lever right? I have two charts that came with itCrank the base up to 650 and put 1g on the levers. I would set the tamer at 1 turns from quickest rebound. No hero runs for at least 3 hits. If it sounds ugly GTHO of the go pedal : D
