Anyone Ever Had This Problem B4 Bet Not!
63VALIANT*KISS
Eureka,Ca Humboldt
So Water Was Leaking A Bit Out Of A Freeze Plug Is What I Thought But Further Investigation Leads Its The Water Passway From The Block To The Timing Chain Cover Seaping A Lil Drip Of Water Evrey Couple Secs. Guys At The Car Parts Store Said Run Some Stop Leak Through It So Far I Havnt Seen A Leak Anyone Know What All That Jazz Is About?
you lose,,,,,i just fixed that same problem,the gasket between block and timing cover starts seeping from the bolts holes that are in a water jacket.
if it is not he bolt that is directly under the water pump neck,you can just wrap some teflon tape around the threads and put them back in,without having to pull the water pump.let me know if the stop leak worked.
