Anyone using a battery mat?
dibbons
La Paz, B.C.S., Mexico
Spent the last couple of mornings inspecting, sanding, and priming the damaged driver's side inner wheel well and battery tray due to acid in the area through the last 4-plus decades. Why don't all cars have the batteries sitting on those acid absorbing mats?
It would be a waste for me, many cars over many years, never had a leaker. Over charging is a good reason for them to spew acid.
Something UNDER the battery will really do no good if the acid is cascading off the TOP
charging and discharging a battery causes the boiling and moisture on the outside. So batteries of yesterday with many well vented caps combined with a weak charging system that drained and recharged the battery almost constantly would cause a mess. Those needed water added semi annually or more. You probably have more rust under that corner of the hood too.
Todays stuff is different and better in many ways. A maintenance free battery has such a small vent that of it does boil that much it will swell its sides. Proper charging system is the most important factor.
