Anyone using a stroker cast Eagle crank??
myasylum
Las Vegas, NV
I have a cast stroker Eagle crank in my car. I didn't hear about any of the bad things till after I bought it (of course) Now I think I would have gone with a Scat.
I only have about .04 miles on my engine now, so I really don't have anything to compare it too. So have any of you used this crank and have 100,000 miles on it? Are some people having good luck with it?
It was internally balanced at the shop, so I'm sure that will help.
Thanks!
You're smart to check the balance. The machine shop that's doing my motor
said he's had a few cheap cranks that he was unable to balance. It's best not to take them out of the box and bolt them in. Way too much work to take them out to make it right. How do you like your big cube motor so far? toolmanmike
