Anyone using McLeod Super Street Pro Clutch
duster360
Alabama
I need some input from those of you that are or have used the McLeod Super Street Pro Clutch. My centerforce pressure plate has gotten very weak with less than 1000 miles on it. I am thinking about using the McLeod this time because I don't like the weights on the centerforce pressure plate.
That’s the clutch I run, it’s very bitey and my first old style manual trans car so I don’t really have much to compare it too, but I also run a light weight flywheel which makes it more sensitive, sure has been working well tho!
Just make sure you have decent parts behind that clutch if your hard on it
The Centerforce I have is kinda grabby. I have adjusted to it. How many miles have you put on the McLeod clutch?
I’m not sure on mileage, but I’ve been through 50 couple gallons of fuel, I’m super hard on it every time I drive it,
Clutch adjustment hasn’t needed changed since I set it up. No slippage yet clutch holds like the day I put it in
