are a and b boday front spring hanger brackets the same
vkute265
Brisvegas, australia
im loooking at some caltracs off a b body, but im unsure if the the front hanger brackets will bolt up to an a body
can anybody confirm if they will bolt up or not
thanks
Ash
The length will probably be too long rather than the perch being too narrow.
Some B-body ones aren't the same as other B-bodies let alone an A-body.
thanks
Ash
Why not go to the Caltracs' catalog and see if the part numbers are both the same for both body styles?
According to Mancini's catolog it looks like they are more dependent on the length of the front spring segment. They are either 20" which is standard for A-body or 22" for standard for B-body but if the B-body they are off of ran super stock springs they will fit as the super stock springs have the 20" front segments.
