Polygraphite had some noise when cold and going over speed bumps.
Don't notice it anymore.
I'm either used to it after 6 years of driving or something has changed.
Poly bushings are prone to squeeking - that's why they came out with the graphite impregnated bushings - to help eliminate the squeeks. Either way, lube the heck out of them prior to install to help prevent the noise.
Thanks guys. I got my leaf spring hangers in today. I thought they were supposed to be black, but they have that yellow coating on them instead. I guess its for strength? I put them in place and they seem to fit so I assume they are the right ones? The only reason why I ask is because the auction on ebay said they were black and the ones up for bid with the yellow coating on them were for the B-bodies.
Thanks guys. I guess ill use the graphite impregnated bushings and regular shackles in back. Do you think the stock style shackles will be ok with my car? It wont be a drag car, but i saw some HD adjustable shackles.
