ASSEMBLY LUBE
CFD244
"I LOST MY ID IN A FLOOD"
Northern Ontario, Canada
Hi Folks
Has anyone tried this stuff as an assembly lube for engines, transmissions or differentials? The bottle says that is is not solvent based and mixes with engine oil and/or transmission fluid. Nice and gooey and stays put.
Thanks
Isn’t that Lucas stuff akin to Slick 50 with all the marketing nonsense? IDK, I haven’t tried it and see zero reason to when there is this:
I’m a proponent of using assembly lubes specifically for the application, not a one size fits all.
I got a case of it along with a case of Lucas engine break in oil from a guy when I went to buy a transmission Jack. He was closing his shop and gave it to me. That's how I got it. Looks like it would be good for chain lube because I would never dump a bottle of it in my automatic transmission.
I'd use it to lube my Poulan chainsaw, but that's about all. You get what you pay for.
Permatex Ultra Slick is a really good product.
I used permatex on mine i had a small bottle of this green assembly lube that came with my crank bearings It was really really thick I used it on the bearings since thats what they came with and used permatex on everything else.
Clevite bearing guard is all of used for years. When I worked in the engine shop we always used it on the ford mod motors because you couldn’t prime the oil pumps. Stuff does a great job at protecting the engine on start up.
