There are several different correction factors people use.
The most common is what I use and that’s the SAE J607 which corrects the observed power from the dyno (the actual power the engine makes on that day at that time with those conditions.
The correction factor then takes the observed numbers and “corrects” them to whatever factor you are using.
For example, I use the above CF which corrects the observed numbers to 60 degrees, 29.92 barometer and zero humidity. I call those Disney Land conditions.
But, I can drive about 3.5 hours from here and in the spring and fall I can get those conditions and better.
They roughly convert to a density altitude of about 100 feet.
The CF that Blueprint is using converts the observed numbers to a higher temperature, lower barometer and higher humidity.
The exact numbers I would need to look up but their corrected number will be lower than my corrected numbers for the same observed numbers.
Damn that’s a horrible picture. If you look at the bottom right corner you will see my current readings. Some of them anyway.
You can see the actual density altitude is 1672 feet and the correction factor is 1.059. That means that my corrected numbers (if I were making a pull but today I’m developing a timing curve so ignore the unzero’d torque number) will be 5.9% HIGHER than whatever the observed number is.
On Monday my CF was 3.3% and for where I’m at that is smoking good.
In the summer I’ve seen the CF be as high as 13%.
And that is exactly what the correction factor is for. It allows me to test year around and using the corrected numbers I can tell if any changes or upgrades I made actually made power. Or lost power.
If we just used the observed numbers then any pulls I made on Monday would be about 2% higher than today so I’d be losing power from the conditions and I’d never know if I made 10 ho or lost 30.
That’s why you use a CF. As long as you use the same dyno and he uses the same CF every time you can trust those numbers. At least as far as if it made or lost power.
I watched a video the other day of something Just Mopar Joe had on a dyno.
The CF that day was MINUS about 3%!!! So the correction factor was LOWERING the corrected numbers back to STP correction. I believe that is the CF that dyno is using.
It’s not that Blueprint is wrong using the CF they do. In fact I can make the argument that for the customer base they have (I’m not knocking their customers at all, I’m just saying most guys buying from Blueprint want to drop in a tested engine and go) that using a CF other than STP is better.
It shows a lower corrected number and the engine in the chassis is more likely to make power much closer to what their dyno sheet says than if they used the STP CF.
That saves them a ton of phone calls and things like that.
So good on them for doing it and putting it on the dyno sheet so guys know what they are getting.
