Auto to manual swap
Hemi_Manny
New Member
Naples
I’m fairly new to FaBo and haven’t figured out how to properly search. I’m sure it’s on here more than once. But can some one give me a parts brake down of what I need to swap my barracuda over to manual? Which trans I choose is still undecided but it needs OD. I’m going with a 408 stroker and 8 3/4 protouring car. End goal would be a t56 but maybe just a cheap 5 speed for now? What are your thoughts ?
A 408 makes more torque than the cheap 5 speeds can handle. You will need a Passon 855 or a Tremec TKO for an OD 5 speed. The Passon unit is a bolt in, a much cleaner installation.
Passon also makes an overdrive gearset for 18-spline A833s that has a closer spread of gear ratios. Cheaper and easier to get ahold of than an 855
I'm daydreaming again...a few questions on my mind:
Has anyone done a T56 swap yet? Is it that much better than a TKO 5spd?
What are the hard parts of this job? Is any welding (mounts, floor, etc.) required?
Can this job be realistically done with ramps/jackstands? I have pulled/installed my A904 without a lift...but I can imagine that some of the aspects of this job might be difficult from the supine position.
Is this something that an average mechanic should even think about?
T56's are a lot bigger. You have to modify the tunnel for either the TKO or the T56. Talk to American Power Train or Silver Sport Transmissions for a complete kit.
Ok I'm wondering why an A833 would not be enough with a 408, in a protouring car....... What else does a protouring car do?
Have you given any thought to a two-speed rear, like a Wilson Quick Change?
