MoparFan
Hi,
this morning I found an ad about an A-body 8-3/4", so I call the guy. Here is the deal, it's a A-Body 8-3/4" empty housing with the back plate (need to be cleanded and painted), axle for this housing and a pumpkin (don't know wich cast thought) but it has been clean/sand blast/painted, and a set of 2.76 gear with a lock unit (maybe Sure-Grip). Don't know if the axle have been modified for the BBP either.
The whole thing is disassembled and he ask me 250$cnd for this...wich I think is pretty damn good price, but maybe i'm wrong?:neutral: :burnout:
So, there is no brake system on it, but can someone tell me if the 10" drum/pad/brake cylinder/hardware from a '74 8-1/4, would work on it?
Also, how much can it cost to rebuild it, bearing and other stuff needed (considering i'm gonna do it once and for good), also gonna change the gear?
Thanks again
Thanks again
