[WANTED] Axle Bearings and Seals
Is there only one rear axle option?
Is it the stock rear axle?
In 63 they used 2 different bearing, I am not sure about the seals. Best to take it apart and get the bearing and seal numbers off the old parts.
Instead of looking the parts up by application,use Rockauto's part number search feature.
Search these Chrysler numbers:
2421349 bearing
2404052 seal
2467095 flange gasket
As far as I know, it's stock - everything else on this wagon is stock. And yes, for the Valiant/Dart for '63, there's only one stock option.
Here's what my manual shows as P/Ns:
Seal (there's just the inner): 2404 052, Qty 2
Gasket: 2070 997, Qty 4
Bearing: 2421 349, Qty 2
Rock auto has them listed.
Yes, they have them listed - but they also indicate that they are out of stock. Rock Auto is my first go to, but no help this go around.
2421349 bearing
2404052 seal
Curious that the bearings turn up on search by P/N, but not for the vehicle! OK, I'll go with that. But... my '63 parts manual shows a different P/N for the gaskets (two for each side).
...and the gaskets (like the bearings and seals) show up under the '63 Valiant listing when I search for those P/Ns! I will go with it. Thanks!
Dan
Chrysler superseded the original flange gasket to a new number.
2070997 changes to 2467095.
