axle broadcast codes!
If you post the year model and other info or send it to me,I will decode it for you.The code is read as D87.This should be line two of the build sheet.Double check the code to be sure,as to not read the engine code,as a E87 is a 440 6 pack motor and if it is a manual tranny,the car would be a dana,Mrmopartech
Check your VIN tag to see if you have a Lynch Road Plant built car,or if it was built at another plant.And send me a copy of your fender tag or a scanned copy of the build sheet.The codes for the diff are on line 2,numbers 4&5.4 is the diff ratio and size,box 5 is for the open diff or sure grip,Mrmopartech
