I'm installing a sealed bearing conversion kit in my 8 3/4. The kit came with only two flange gaskets. I'm trying to understand the sealing requirement for this install. The bearings themselves are sealed. There is also an O-ring on the outer surface of the bearing. Also two inner axle seals are included. To duplicate the original gasket combination, I would need another pair of flange gaskets. Anyone?????
