ValiantOne
Why is it necessary to remove the thrust spacers to run the green bearings?
So the thrust blocks actually impede the full seating of the green bearing axle?
I was wondering what they actually did in a stock (taper bearing) set up too. When you set your axle end play are you drawing the axle ends up against the thrust blocks? It just seems like a flimsy set up to transfer all those latteral forces. Must work fine though, as they've been doing that job for 50+ years!
I'm setting up my first 8 3/4 right now so this is new to me.
Thanks,
CE
If your going to use greens, remove the thrust Buttons/Block regardless if you have either type of suregrip or pegleg.
If you leave it in and the axles with the greens don't go in all the way because of the thrust block and you tighten them down and run em like that your going to destroy the greens in short order IMO
