dusted72
Thanks Hemiroid!!!!
Ok I know that the spring perches need to be moved but when I measured the width of my 7 1/4 then the 8 3/4 there was only a half an inch difference between the perches. So does that mean I have to cut off my perches and move each one a 1/4 inch? I already put it in the car just see if it would fit with no mods and I had no issues with it fitting. Went in first try right onto the little alignment bolts through the springs. So what gives could the perches have been welded on at the wrong place from the factory? The rear came from a 68 Satellite 2 door 318 auto 2.73 open diff. I included a pic but it doesn't show the fit ust the fact that it is in there, I also know the tires are way to big for it those are just rollers 235/75/15 on Magnum or Cordoba wheels.
