B&M floor shifter in a valiant
spudsterier
mendota, il
i was wondering if anyone knew if the B&M z-gate shifter would work in a 68 valiant with a 727 auto from a 1974 dodge van?
the car is originally a manual trans with the shifter on the column...i was going to replace the column with an different one from an auto with the shifter on the column, but i have been tossing around the idea of just using a floor shifter instead....
good idea? bad idea?
My valiant was the same way....I used a b&M star shifter..you can find them used, pretty cheap..
