240 gordy
May not be on the correct thread but would like to know what separates the back seat and the trunk. Is it a hard board fiber board or or jute or what. What was the original piece ?
It's a one piece hard board material like a glove box insert material. It is probably thicker than that. It usuallyMay not be on the correct thread but would like to know what separates the back seat and the trunk. Is it a hard board fiber board or or jute or what. What was the original piece ?
Thanks guy's just what I wanted to hereIt's a one piece hard board material like a glove box insert material. It is probably thicker than that. It usually
has cut outs and slips over the upper hooks for mounting the seat back. They are probably reproduced or one could
make their own. If you had the old one it could be used for a template.
Talking about the piece that seals the interior from the trunk? Get a piece of 1/2 inch plywood and use the old one for a template. Cleaned and repainted the hinges, added carpet on the interior side and stained and clear coated the trunk side. Turned out pretty nice.
