Back-up (reverse) Lights Heads-up for Early A's (FYI)
dibbons
La Paz, B.C.S., Mexico
With only a partially assembled wiring harness, I failed to find the reason for the reverse lights not working on a '65 Formula S Barracuda. After consulting the wiring diagram, I found the power source for the reverse lights is a white wire that comes from the wiper motor switch/harness. With the wiper switch wires installed, the reverse lights now are operating. This, of course, is with the floor mounted automatic shifter and corresponding console.
While I was at it, I found the dash lights would not work. I found an internal short in the headlamp switch. I swapped in another switch from a parts car and the dash lights worked. Now I find with the headlight dash light dimmer turned all the way counter clockwise (to operate dome/courtesy lights with doors still closed) the dash lights go out. Still looking for that problem. I guess it could be the headlight switch from the parts car has an internal short (of a different kind) as well. Still looking for that solution.
I just read on another thread that the '65 Barracuda and '65 Valiant have different circuits in their respective headlamp switches. I'm not positive, but I believe the front parking lights turn off with the Barracuda when the headlamp switch is pulled all the way out.
I looked up both '65 Valiant and '65 Barracuda on Summit website and the same 3 headlamp switches were offered for both models: DS165, DS165T, and OER MD9341.
My '65 Formula S switch has Mopar 2580463.
That’s normal for the dash lights to go off with dome manually turned on.
Don’t invent more problems!
