I have some 10" five hole flange (8 3/4, Dana). can someone tell me how I can tell if they are for A body brakes? It has to do with the offset of the flange mounting area, but I've forgotten exactly how. Thank you drive through.
Ok, measuring JUST like you describe, I got 1.750. So these are 10" B body plates then?If you put the backing plates flat on a table with the e-brake mounts hanging off so the plate sits flat and measure down through the center of the plate to the surface
10" SBP plates should measure ~1.25"
10 or 11x2.5" plates should measure ~1.75"
11x2" plates should measure ~1.5"
11x3" plates should measure ~2"
Gotcha. Thank you kindly.They’re BBP plates for sure, don’t have to be B-body but they’re 10x2.5”.
what did 11x2" brakes come on? have them on the dart and swore i got them from a 67ish newport but can't find them.. i want to re do them....
yea, 2.5" would sell better. i have the 2" on the car already though.try napa. i have some 11 x 2 and was thinking of rebuilding them but do not see a market for them as good as my 10 or 11 x 2 1/2 are.
ok, found 2.5" backing plates and drums.. is all the 2.5" shoes and hardware the same???
sweet.. figure if i'm doing them i may as well add wider brakes..![]()
