So I have been having issues with my Jeep with a small block 360 LA. I run a megasquirt ECU and while cranking my tach on the computer goes crazy. It will spike past 10k. So, it will not want to start since it thinks it is spinning fast and is requiring more fuel causing it to just flood out.
I took the cap off and I can wiggle the shaft a good bit... 1/8" or a little less. Either way its noticeable.
I also put an adjustable timing light on it and it jumps around. Also, when I go to start it sometimes it acts as if timing is off.... the starter kickback happens.
Now I have a off-road trip planned this Thursday and think I need to replace the distributor. Rite now its just the stock unit with the dual pickup (only use one pickup) wired to a MSD 6AL box and blaster coil.
The engine is around 10:1, aggressive cam, flat top pistons, headers, yada, yada, yada.
So will a stock replacement from the parts store for $40 work ok? I do not use the vac. advance since I do not make any at idle. I do not have the funds to buy a MSD or Mallory or spend $400.
Thanks for the help!
Kirk
Kirk
