bad door line up
Snake
Mopar Nut
Belleville Canada
This has been the way I got it back when I had the body and paint done:angry7:Ok so the drivers door at the bottom near the rear quarter sticks out the top sets almost flush.Were would I start at the bottom hindge to adjust this door.The body guy never got the fenders or doors right he even removed them.So I would like to adjust them myself.Also the doors had new pins and bushings.
You said the top was almost flush. If top is out like the bottom, carefully move the latch post inward. If the door still needs adjusted at the hindges, loosen the door to hindge bolts the retighten one just snug. Close the door and bump it with your hand to move it on the one snug bolt. Carefully open the door and retighten all.
