Shamrock--WV2NC
I filled up with 89 non ethanol from the same place I always do. I drove about 1/4 mile and the car started spitting and sputtering dying out several times. I managed to get it home which is only half mile away. It’s back firing out the carb when I push the gas. It started idling fine so I thought a trip around the block. Up to 1500rpm it did ok. When I got on it, it was like it wasn’t getting gas. So I limped it back home. Bad gas? Is there something I could add to it to help? I just filled up. Gas gauge doesn’t work so I fill completely up every 100 miles. I’ve been working and today was the first day I had daylight to do anything. I filled up Tuesday. But I drive it Tuesday to work and back. Then drove to store with no issues. It started right after filling up on the way home. Any suggestions?
