screeminDemon
I removed the intake manifold from my newly built 360, which I've only run about 30 minutes because its been running rough, and I'm replacing the Torker intake with a Performer, and replacing the carb.
Discovered the camshaft still looks great thankfully. But #1 cyl exhaust rocker still really loose (I noticed it once before when I removed valve cover while troubleshooting rough idle). Do I have a hydraulic lifter that only pumps up when the motor is running? or should I replace this lifter?
Can a guy replace only 1 lifter?
Thanks again for your help mopar fans!
