Bad starter relay?
Discussion in 'Electrical and Ignition' started by StewsDart, May 12, 2018.
  1. StewsDart
    StewsDart Member
    23
    5
    Mar 22, 2018
    Western New York
    Local Time:
    1:34 AM
    I just got finished up installing the new 408 in my dart. Now I can get the car to fire up my jumping the starter relay with a screwdriver but I get nothing when I turn the key. Does that mean the starter relay is junk? Or did I miss something along the way?
  2. 67Dart273
    67Dart273 Well-Known Member
    38,301
    5881
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    10:34 PM
    Stick, or stick with clutch safety switch, or automatic?
    IE how many 'push on' flag terminals does the relay have?
    ONE flag terminal means there is no safety device AND THE RELAY must be grounded.
    TWO flag terminals means the second flag terminal goes "to ground" through a safety switch, either the neutral switch or the clutch safety switch
    I see you say 69 Dart so that should not have a clutch switch, but is it stick or automatic?
    START by probing the connector on the YELLOW wire flag terminal at the start relay. Twist the key to start and see if you have a light/ 12V
    If so, move the meter to the second flag terminal which (automatic) goes down the firewall to the transmission NSS. This should GROUND in park or neutral
    If you have power at the second terminal, IT IS NOT GROUNDING which is needed to activate the relay
    OH............and check the transmission linkage.......Twist the key to start and wiggle/ move the shifter see if it cranks or "tries" to
    Then go down and be sure the connector is installed on the transmission
    • Like Like x 1
    • StewsDart
      StewsDart Member
      23
      5
      Mar 22, 2018
      Western New York
      Local Time:
      1:34 AM
      It is an automatic with a hurst promatic ratchet shifter. I don’t believe it is a neutral safety switch problem but I will double check that. Thank you for your help
    • 67Dart273
      38,301
      5881
      Oct 14, 2010
      Idaho
      View My Photos
      Local Time:
      10:34 PM
      You can easily test the relay if you have a couple of jumper clip leads. Just clip one flag terminal to ground, and jumper the other to the big stud which is always hot. BE CAREFUL that it is in park!!!
    • Dfr360cuda
      Dfr360cuda Well-Known Member
      805
      184
      Aug 30, 2012
      Finleyville, pa
      View My Photos
      Local Time:
      1:34 AM
      Also.....
      It may be too late for this but, there is a thread on here somewhere that shows how to put a diode between the 2 terminals that will protect electronics. I'm probably going to be doing it to my cars.
    • d1970
      d1970 TODAY IS A GOOD DAY TO HAVE A GOOD DAY
      355
      145
      Sep 29, 2015
      Ontario, Canada
      View My Photos
      Local Time:
      12:34 AM
      being an automatic, try to start it in neutral, if it starts you might have to adjust the linkage because the transmission is not in park to let you start the motor
    • RSP69
      RSP69 Member
      6
      0
      May 13, 2018
      Santa Rosa Valley, CA.
      Local Time:
      10:34 PM
      Hello, been away from the site for some time now but still have my 69 Dodge Dart 340. I have a starting problem with my car that is similar to the above. My Dart has a 727 automatic trans. The relay is of the 2 push on wire connectors type. (yellow wire and brown wire) I checked the yellow wire with a test light and when the key is activated I have a proper connection. The 2nd brown wire going to the trans.was also tested. The probe was placed into the brown wire and the key was activated the engine turned over and fired up immediately. Was this simply because the probe test light made the ground? And therefore I have a bad ground at the trans? Obviously I am a novice at tracking down electrical issues..
      Thank you, bob
    • 67Dart273
      38,301
      5881
      Oct 14, 2010
      Idaho
      View My Photos
      Local Time:
      10:34 PM
      May be a bad connection, and probing it may have "made" the connection Check to see if the flag terminal is loose where it's riveted to the relay, "work" the flag connector in/ out a few times to scrub it clean and "feel" for tightness. Then recheck.
      the current path is..................
      from ground at the NSS, ----------up the firewall to the relay flag terminal,--------- through the relay coil, ---------- out the "yellow" start wire, --------- through the bulkhead connector ---------- and to the ignition switch.
