Bad water pump?
billytuffnuts
Newport Beach, CA
Installed a new water pump on my 360 and after about 5 minutes of run time, coolant started pouring out of the weep hole. As far as I know this indicates a bad pump, but being that its brand new (not rebuilt), before I return this, is there anything else that may have caused it to fail so fast?
I just got the engine back in after pulling it to swap camshafts, replaced the headgaskets, installed new freeze plugs.
To me at least that sounds like a bad unit. Out of curiosity where did you get it?
I hope theres a warranty.
You are right....5 minutes of run time shouldnt kill a water pump.
My question IS:
Did you have coolant in the engine and radiator....up to the bottom of the thermostat, before start up?
If you forgot and cranked it and had not filled the radiator....the water/coolant may not have been at a pumpable level and it could have burned up the shaft seal....That is WHY waterpumps fail....shaft seal leakage....either from heat....or age.= weep hole leakage.
:read2:
bad pump in my opinion it really dont matter where you got it because most rebuild shops only repair whats wrong and it sounds like yours may have been shipped to fill qouta good luck on next one
Bought it from rockauto.com. Was only about $20 so I'm debating on whether it'd be worth having to send back since shipping will run about $10 on it.
My question IS:
:read2:
Hmmm thats a very interesting thought.
I filled up the radiator before starting the engine but after it ran the level dropped off and I had to add another half gallon to gallon (dont remember exactly).
I can't say for certain if it reached up to the thermostat or not...how would I without physically removing it?
The pump was a brand new unit not rebuilt.
$20 or $120?
New pumps are not $20.
