Baer Brakes?
redlinegw
Shannon
Newhall, CA
Anyone install Baer brakes on there A-body? I have a 69 Valiant that is being converted to a pro touring setup and it is going to get 4 wheel disc brakes and a complete Hotchkis setup. I am planning on running some 17 inch wheels so does anyone have a good idea what the offset should be front and rear? I have an 8 3/4 rear with Yukon axles. Also any tire size suggestion? Thanks all!
Shannon
How about Baer rotors with Porsche calipers? This is what I have on the front of my '65 Coronet. Same stuff fits on an A body if you use the late model knuckle.
Here is a Baer kit on a Mopar. 15 inch rotor with the big 6S caliper. Baer has a bunch of different kits. For a 13 inch rotor you'll want either a T4 or a 6P kit.
Hi,
I was wondering what caliper bracket you’re using for this?
Thanks
