Scott Warner
So my late 1968 318..yes it's in a B body but theres more small block knowledge over here. Anyway..numbers matching block in a 1969 car. I was swapping cams tonight and realized I have a 70 and up timing cover (drivers side scale) which I knew...and my forged crank balancer is keyed to work with it which i didnt realize till now. There is evidence the motor was removed and rebuilt back in around 1984 (by the date I found on the cam sprocket and the corporate blue instead of red paint on the engine). I thought the 70 and up 318s were generally cast crank....could there have been a kit back then of a cover/balancer to go with the newer design? Or do yall think it was just a mish mosh of parts? I ask cause the scale is behind the lower radiator hose...so basicly unusable. Thanks yall.
