Ball Joint Adapters
i cut out the sockets and welded in large sockets for a fraction of the cost. i also moved the socket in to compensate for alignment ease.cracked back tiped me of to the sockets frostock car products. worked grate.
hears where i got them. http://www.stockcarproducts.com/susp7.htm .call them and tell them what your doing before you buy to make shure you get the right sockets. i used a torch to cut out the small bj sockets. i made the holes a little small and trimed them with a high speed die grinder. then i used a stick welder to weld the sockets in on the bottom side and then cut off the excess socket.
I thought I saw some on here or moparts for $60
that kinda money you might as well spring for tubular ones, as they come with new bushings and ball joints
