Rapid Robert
where do I go to get torque specs: ball joint tapered mounting studs & ball joint to spindle mounting bolts? thank you for your time. RR
Probably the upper bolts for drum brake backing plate.steering knuckle bolts (lower) 100 ft lbs. are these the 2 bolts that bolt the lower ball joint to the spindle? steering knuckle bolts (upper) 55 ft lbs. which are these? thank you for your time.RR
steering knuckle bolts (lower) 100 ft lbs. are these the 2 bolts that bolt the lower ball joint to the spindle? steering knuckle bolts (upper) 55 ft lbs. which are these? thank you for your time.RR EDIT are the lower ones the ones that bolt the lower ball joint to the spindle and the upper ones are the ones that bolt the brake caliper bracket to the spindle?
Al whats you smokin? got any left!About four and a half ugga duggas. With blue Locktite.
Just shaking my head, just shaking my head!About four and a half ugga duggas. With blue Locktite
real professionals use pneumatic seconds... and red loctite, cuz **** the next guy.About four and a half ugga duggas. With blue Locktite.
lolreal professionals use pneumatic seconds... and red loctite, cuz **** the next guy.
*and then you are the next guy (womp, womp)
Are we on Facebook?real professionals use pneumatic seconds... and red loctite, cuz **** the next guy
i mean, the torque specs in the FSM is are only suggestions what do those guys even know? and who even owns a torque wrench? ain't nobody got time for that! i gotta make book!Are we on Facebook?
Shaking head yet again![]()
A friend worked in a BMW dealership. He was doing something that required the transmission to be seperated from the engine. On reassembly he broke an ear off of the transmission, he asked he's manager what he should do. Manager said send it!ain't nobody got time for that! i gotta make book
oh my friend... my sweet summer child... that is the way of the sword at dealers.A friend worked in a BMW dealership. He was doing something that required the transmission to be seperated from the engine. On reassembly he broke an ear off of the transmission, he asked he's manager what he should do. Manager said send it!
