Do I need to use a ballast resistor with an after market wiring kit. In this case I have a slant 6 with points ignition in a 72 Dart. Someone put in an E-Z Wiring kit that is a rats nest. The wiring diagram that came with it is basic at best.
Thanks, right now there are some wires attached to it but it hard to tell where they are going... It has a single wire alternator and a new style voltage regulator.Yes usually a .5-.6 ballast, check your FSM. Only time you delete it is a one wire alt, Petronix etc.
Between the coil + and the power wire for the coil.
