Looking for the correct paint for the rear moldings for my 68 barracuda. The black stripe, I cant get any paint to stick to the metal. about to leave it natural.
hard to get paint to properly stick to aluminum, as said you can use 1/4 inch black pin stripe tape. I use cerakote to do aluminum, but it is very expensive and coats real thin and needs to be heat baked to dry.
The 67's actually used tape and not paint on the upper and lower trim. The tail light housings were painted black.
Neither paint or tape wants to stay on the chromed tail lamp fixtures. I have better luck with 3m tape. Die cut curves from wide tape stays better than 1/4 wide stretched and turned.
