Hello there,
I'm working on a 65 Barracuda, and I think the little flat metal that goes from the lock to latch fell out, as the key turns 180 degrees without catching anything.
What is the easiest way to get into the trunk? Will I have to take a hole saw to the divider to get in and manually pop the trunk? If so, how hard is it to find replacement wood panels?
Would it be easier to drill out the lock?
I appreciate all help in advance!
Thanks,
Brett
Thanks,
Brett
