[WANTED] Battery tray support bracket
Speed Junkie
Matthew
Vacaville, California
I am in need of a battery tray support bracket because the bolt on mine is rusted to the bracket.
If you soak it in a molasses solution it will clean up nice and the bolt will come out easy. I have done this with lots of parts. some pretty cool videos on you tube about this.
Mike m
You can soak it in white vinegar too. Or EvapoRust but the vinegar is cheap.
Thank you guys for all the replies and Pm’s. I forgot I had some Evapo-Rust. So I’m soaking it in that. We’ll see how it goes, and if it doesn’t work ill have to purchase one from a member.
