[FOR TRADE] BB Camshaft and Lifter - Possible timing chain
Cazbah362
Nevada
I have CompCams CRB 270H-10 camshaft and lifters used on my 440. Engine made 425 HP with this in it. Engine had about 300 miles on it and broke a hyper piston skirt edge. This is a one bolt camshaft. I have the original card.
I have a new dual roller timing chain with crank gear which has multiple advance/retard settings. Nice, new and tight.
I would like to trade the above cam and lifters for a nice mechanical cam 550ish lift - and lifters. Would like a more modern grind - I am not a cam guru, so please talk slowly.
Since this is a single bolt, and the cam you have is a three bolt, maybe we can talk about the timing set too. If its a one bolt, I will use the set again.
Any interest - please PM
Charles
