BB oil pump applications
Bulldozer
free ice cream sandwiches
behind the wheel
high pressure VS high volume
what are the applications of these and what deems them necessary?
would one even be necessary with a fresh bone stock 440 with a 699 pan ?
LOL funny Rick, thats the exact one i ordered. im doing good , how about yourself?
Ok, for now, but Wed. is right around the corner. I'm positive things will work out though:thumblef:. Don't want to hijack:D, other pump opinions will come.
prayin for you guys :D
i was just curious as to when people use HV pumps compared to HP pumps, and why
Thanks, we'll talk later.
Well, the engine guru's, which i'm not, may disagree and i can't argue with them, but any SBM, SBC, BBC, & SBF i had a hand in that used stockish clearances and a 4/5 qt. pan got a standard pump. The few racier engines got clearanced on the high side and got high volume pumps, but had 8 qt. pans. The only engines i was associated with that required high pressure (70lbs +) were big bearing engines like big Buick, Olds, Pontiac and the FE Fords (390,427,428). I don't have any experience on BBM's other then stock/factory assembled. I know there's a formula out there for this, but i don't know exactly what it is. I do know that i never lost a bottom end on anything i worked on, rod or main.
.............Hv is used when u have bigger clearances than factory..........hp was used on factory hp engines and stock pumps were used on granny engines........kim.......
I've run all 3 style pumps and my biggest concern was when using the HP or HV pumps you were always up against the oil pressure relief when the oil/engine were cold. This is fine if the valve works fine but if it fails once that 80PSI oil pressure will be at 120-150 which could rupture the filter can and yes I ran the mopar heavy wall high pressure filters. End all be all is unless you're running 750+ HP (very high rod bearing load) or are into high crank/rod bearing clearances the standard pump is fine. Don't forget to purchase the oil pump rod with the hardened ends for any and all pumps, cheap insurance.
