MRL Performance
Spring Time Special
BBM 400/500 stoker kit for sale
Kit has the following
PEP/RPM 4.150" 4340 Forged Stroker Crank
PEP/RPM 6.760" 4340 I-Beam Rods
Total Seal Piston Rings
Seal Power/Speed Pro Rod/Main Bearings
JE Flat-Top Pistons 4.375"
This kit is being sold NON BALANCED. You have to do your final mock-up before balancing with most of the 4.150" Low Deck B Block storker kits as there might be the need to clearance the counter weights and/or block due to BBM core shift and 40yo machining processes.
$1850 plus shipping, Thats a steal!
