71scamp78
What is the correct type of bearing grease to use on rear axle bearings. Wasn't sure if there is a certain kind needed to use
I'm not opposed to the red and tacky, but I'd suggest if you're driving in winter to reconsider. That stuff can set up hard when cold, and actually cause a bearing to skate.
