Bell housing needed
dodgewade
Active Member
Rating - 0%
0   0   0
I need a bell housing that will mate up a 318 engine with a 81-86 3 speed w/overdrive transmission. The trans is a A833 4 speed that Dodge just converted to a 3 speed w/overdrive. I really think most any bell housing that will fit the engine and a A833 trans will work. The center hole is 5 1/8". This is not a big thing, I could have the hole rebored.
Thanks
I have one for a 23 spline 4 speed car. i believe its a 69 bellhousing which would fit your 318. I will take pics tomorrow and measure the hole for you.
the ID will be too small unless he wants to bore it.
If he doesn't want yours, I know of someone local wanting just what you have.
If you bore the hole I'm not sure you'll still have a place to mount the fork pivot. I think your best bet would be to get the prober bell housing for the OD trans.
