Can I use the bellhousing from a 1989 Dodge pickup with a v6 on a 1970 340 motor for a 833 overdrive conversion. The 833 has the larger 5.125 front bearing. Would I need any other parts from the 89 truck v6 for the swap, like the flywheel or clutch?
Make sure the bolt pattern is correct where the bell meets the trans.
IIRC most "later" trucks use a different pattern.
Might be a "435" transmission.
.The truck bellhousing's do work, the clutch fork pivot is different, as is the fork. I believe you'll have to use the A-body version of both, but I haven't done it to be sure.
