[WANTED] Bellhousing
Unless I am mistaken, there's no difference between a standard A833 and the OD A 833 in terms of the bellhousing. I have a SB unit, 9-1/2" clutch, casting number 2465523. It shows as a 64-66 unit for a 273. I'm not any kind of SB wizard, but I'm sure someone smarter than I am - which is just about everyone - will chime in if this will fit.
The OD units are specific, are a different casting number and have a larger diameter to accept the larger OD bearing retainer.
I have one, as well as a cast iron OD A body box, floor hump and most parts needed for a conversion. I am saving these for a project that I dont yet have (LOL) and didn't really want to sell, but might.
you can have the opening on a regular bell machined to fit
or machine down the retainer
if you cant find the "correct" bell
Brewers has one listed on their site:
Product ID: BH859
BH859 SMALL BLOCK 10.5" BELLHOUSING, 75-80 A/F-BODY/1976-80 TRUCK OVERDRIVE, RECONDITIONED
Details
Reconditioned original 10.5" small block bellhousing cast #3743859 to fit 1975-6 A-body/1975-80 F-body/1976-80 truck (can also be used in B/E applications with appropriate fork pivot bracket)318/360 A-833 overdrive applications, 5.125" bearing retainer opening, uses 130 tooth flywheel. Bellhousing cleaned, checked for cracks, damaged threads repaired, bead blasted, ready to paint.
SELECT FP859U A/F BODY APPLICATIONS
FP859TU TRUCK APPLICATIONS
FP859B B/E APPLICATIONS--SHORT FORK
Price: $349.95
