[WANTED] Bench seat: ‘65 Dart 4-door
Patrick Taylor
New Member
Sacramento, CA
Hello,
I’m looking for a bench seat for my ‘65 Dart 270. The previous owner took out the original and replaced it with some ill-fitting buckets. Don’t mind if it needs reupholstery or isn’t perfect, as this car is just a daily driver. Located in Northern California.
Thank you!
Hello,
Thank you!
PM sent
Hello,
Thank you!
I have a bench out of a 65 Dart 170 2dr Post. I do not know if they are the same in depth as the 4dr. Any help from other members....are 65 Dart front seats the same in a 2dr post and a 4dr? Just noted that Lee R. responded. Lee is right near you where you could pick it up and save the freight. Thanks. sgrip65
sgrip65,
I’ve reached out to Lee and will probably go pick up the one he posted this weekend. But I really appreciate your reply, and should it not work out for some reason,
I’ll let you know.
-PT
