Grumpyb
68 barracuda fastback I would like a disc conversion with 5 on 4 bolt pattern but I have to see if the wheels I have will work , I have an orginal set of torq thrust 14 in and don.t want power
That is what I would use.5 on 4 BP I believe you are stuck with factory Kelsey Hayes style.
Pirate Jack has a small bolt pattern conversion kit, but it has the much better 73-76 floating caliper setup.
DBK6272A-40-LXB - 1962-1972 Mopar A Body Small Bolt Pattern Disc Brake Conversion w/ Powder Coated Black Calipers
