FMJ spindles out and a set of Dr Diff ball joint adapters (~$50).
Exactly! :thumbup:
You can usually pick up those spindles for under $100 at the local yard, and the adapters only cost $50 from Dr. Diff.
I don't bother with the 11.75 stuff on a daily driver, run the stock stuff whatever you find.
Gonna have to disagree here.
The 11.75" rotors are a HUGE improvement over stock. All of the cars I've swapped and driven so far have been from the stock 10.98" rotors to 11.75", and it is a
noticeable difference. Based simply on the radius of the disk, the increase in braking force is at the rotor is about 8% vs. the stock rotors. And then there's the fact that the 11.75" rotors, even using the stock calipers, have a larger braking surface (because of the larger swept out area). That means it will take longer to heat them up, and that you have more surface area to cool them down. There's a reason the bigger, heavier later cars used 11.75" rotors -they work better.
And since the rotors cost pretty much the same, and you use the same calipers, the only real cost above and beyond the 10.98" set up is $100 for the caliper brackets. I suppose if you really want to get technical you need 15" rims to run the 11.75" rotors too, so that could be an extra cost if you have 14's and were planning on keeping them. But I can't imagine wanting to keep the 14's on a driver anyway (no good tires whatsoever). Maybe for a restoration car, but then you wouldn't be switching to disks anyway.
For $100, a 8% increase in braking force is pretty darn good. And if its really a driver, you may need the those extra few feet. I know I've been in a couple of situations in the last 40k miles with my Challenger where a couple of feet might have meant replacing some sheet metal. People drive stupid.
