73' Duster, 8 3/4 RR.. Whats the largest drum brakes that will fit? OK now where do I find em? I don't think the local junk yards will have the older c-bodys.. to salvage...
The nice thing about MoPars is that you can raid a HD Cordoba for there 11 inch drums and just swap everything on over. I did this for my 8-1/4 rear that was a OE 10 inch drum.
Below the stock crud backing plate which needs to be WD-40 ed or other down and remove the nuts holding the backing plate on. On the 8-3/4 theres 5 IIRC and on the others, it's 4. But all is well when you swap it over.
